1 - 20 of 20 Posts
Check connections first for broken wire.
You just need a wrench or an O2 socket.
Only one size for O2 sensors and that's the one shown. I believe it's 7/8"
Bank 1 Sensor 1 is prior to CAT.
Bad fuse would show codes for both HO2's.
Where did you get an OEM or ACDelco HO2 sensor for $16?
Is your car an SS?
I believe that one is only for the SS, not sure though.
And that is not a sensor, just the plastic connector.
---------- Post added at 04:34 PM ---------- Previous post was at 04:32 PM ----------
I lied, but it's still going to fail regardless. You need the AC Delco.
Discussion Starter #18
Wow that was surprisingly easy. Did need pb blaster. Just popped the hood and went to town.
---------- Post added at 04:18 AM ---------- Previous post was at 04:17 AM ----------
Is there a way to visually see how bad the old o2 sensor is? Ive never seen a used o2 sensor before.
---------- Post added at 04:31 AM ---------- Previous post was at 04:18 AM ----------
Didnt*
Why? Let a sleeping lion sleep.
1 - 20 of 20 Posts
