1 - 12 of 12 Posts
Hello everyone. The other day my CEL came on and had the code P0128 which I am familiar with from about 2 or 3 years ago when I replaced my thermostat with an AC delco thermostat. When the light came on my coolant temperature wasn't reading above 180 F I don't believe. I'm sitting at idle right now after some driving and my coolant reads 189 F and the outside temperate is 36 F.
Does it sound like I need to replace my thermostat again?
Discussion Starter #2
I forgot to mention that my coolant level in the expansion tank is above the cold fill line and I don't have any driveability issues. 2005 Cobalt 2.2L base automatic
I'm sure you already know what that code is, but for anyone else looking at this thread later on, here's the English version:
P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
My guess is that replacing the thermostat would probably clear up the issue. I'm a little surprised that yours is going out so frequently since I've never replaced mine and it's been going strong for ~6 years. How many miles have you racked up?
That code means your engine didn't reach operating temperature in the pre-set delay. This means your thermostat isn't closing tight or the rubber seal has failed.
  • Like
Reactions: Parthros
The last time this happened I replaced it with an AC Delco stat. Should I look into a different one?
What did you do???or get done.
Discussion Starter #11
They replaced the thermostat and a gallon of coolant. According to them the previous person who replaced the thermostat put it in backwards. Very interesting.
1 - 12 of 12 Posts
