Car is a 2008 Chevy Cobaly LS 2.2l auto. I have a weird misfire that doesn't seem to affect the car at idle or around town driving I've done a few hundred miles at slower speeds and never noticed any issues or even slight misfire.
If I get on the highway and do above 60MPH sometimes I will get a flashing check engine light and a noticeable loss of power 1/2 throttle will cause me to keep speed but it could do this for about a mile. If I give it 3/4-full throttle it will downshift and start moving like normal again and the issue will go away temporarily. Some drives it will do it every 2-3 miles other times I could go 50miles without a issue. The only code I am getting is P0300 and when I check the misfires in my OBD2 reader it shows cylinders 2 and 3 as being affected but no code for those specific cylinders misfiring.
This issue started about 3k miles ago and since then I have replaced spark plugs, coil packs, and fuel injectors all with AC delco parts. I cleaned my MAF and throttle body and they seem to look okay. At a loss for what else I could check. It seems like a sensor is getting a inconsistent reading but no idea why my speed or other variables would affect it from work correctly sometimes.
