My 2008 Cobalt has a Cylinder 3 misfire code, P0303. I've changed spark plugs and coil packs, which didn't help. I have Torque and ran some testing, but I have no idea what the results mean. Can anyone help, please?
Mode $06 report generated by Torque for Android
Vehicle VIN: 1G1AL58F587271388
Vehicle Manufacturer: Chevrolet
Vehicle Calibration ID: 126
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 0.4281V** Min: 0.4281V
Test result value: 0.4281V
PASS
MID:$01 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
PASS
MID:$01 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.45018V** Min: 0.45018V
Test result value: 0.45018V
PASS
MID:$01 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.65026V** Min: 0.65026V
Test result value: 0.65026V
PASS
MID:$01 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 1
Test incomplete or dependant test failed
MID:$01 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 24ms** Min: 0ms
Test result value: 0ms
PASS
MID:$01 TID:$80
MID:$01 TID:$81
MID:$02 TID:$8a
- O2 Bank 1 Sensor 2
Max: 800Count** Min: 0Count
Test result value: 0Count
PASS
MID:$02 TID:$8b
MID:$02 TID:$8c
MID:$02 TID:$91
MID:$02 TID:$92
MID:$02 TID:$93
MID:$10 TID:$da
- O2 Bank 4 Sensor 4
Max: 41,190ms** Min: 4,144ms
Test result value: 55,824ms
FAIL
MID:$12 TID:$b0
Max: 2,730** Min: 0
PASS
MID:$18 TID:$02
MID:$18 TID:$12
Max: 0.03052%** Min: 0%
Test result value: 0%
PASS
MID:$21 TID:$4d
- Catalyst Monitor Bank 1
Max: 0mHz** Min: 4,177mHz
Test result value: 19,744mHz
FAIL
MID:$21 TID:$a0
MID:$30 TID:$da
Max: 62.85594%** Min: 6.32374%
Test result value: 85.23625%
FAIL
MID:$3a TID:$c0
- EVAP Monitor (cap off)
MID:$3a TID:$c1
MID:$3c TID:$c8
- EVAP Monitor (0.040")
MID:$3c TID:$c9
MID:$3c TID:$ca
MID:$3c TID:$cb
MID:$3d TID:$c4
- EVAP Monitor (0.020")
MID:$3d TID:$c5
MID:$3d TID:$c6
MID:$3d TID:$c7
MID:$41 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 8Count** Min: 0Count
PASS
MID:$41 TID:$d3
MID:$42 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 2
PASS
MID:$42 TID:$d3
MID:$50 TID:$db
- O2 Heater Monitor Bank 4 - Sensor 4
Max: 41,190** Min: 4,144
Test result value: 56,144
FAIL
MID:$70 TID:$d8
Test result value: 55,408
FAIL
MID:$81 TID:$2b
- Fuel System Monitor Bank 1
Max: 170** Min: 0
PASS
MID:$82 TID:$5d
- Fuel System Monitor Bank 2
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count** Min: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 3,135Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$b0 TID:$da
Max: -74.30399%** Min: 12.64749%
Test result value: -29.1527%
FAIL
P0303 is a still unresolved ECM bug in the DTC system. If you look at these lines;
MID:$a4 TID:$0c
PASS
You will notice that with a sample of 65,535 your car had 0 misfire, yet it registers a count of 3,135 total misfires. ????? Then it goes on to say it pasted the test.
So if there's nothing wrong with cylinder number 3 what is wrong??? I believe it has to to with a CAM - CPS sensor correlation problem. You would need to put a scope on these to find out if one of them is losing it's square wave momentarily causing the ECM to check cylinder number three for misfire when cylinder number 3 isn't even on the firing stroke. Don't know if Torque shows these or not in the list of sensors.
Does your engine shake at all, or slightly knock or tick? If so, you bent a valve. If not, I'm gonna blame injectors. Switch injectors with cylinder 4, delete the code and see if it follows. Do the same thing for your coilpack
Discussion Starter · #4 ·
Thank you, I am still learning Torque - so I will have to look. Yes, the car has a terribly rough idle, and shakes/knocks when I'm sitting in traffic, waiting at a stop sign, etc.
Also, my service traction light is constantly on - not sure if that's related.
Sure it is, this means your losing GMLan communications between CPUs. Try pulling every single fuse and flipping them before re-inserting back into place. You might be experiencing a common problem with BCM corrosion. Give it a try, it's easy and solves problems 60% of the times.
