41 - 60 of 125 Posts
I'm pretty sure an all-inclusive kit includes everything you need...generally...
That's Mr. meogE to you.
This is what's on the ZZP website:
The kit includes:
M62 Supercharger
Custom ZZP modular pulley system
LSJ lower intake using Laminova intercooler
LSJ throttlbody
39# injectors (base kit)
Cooler NGK spark plugs
TB adapter harness
MAF extension
2 bar MAP sensor (2.4L only)
Serpentine belt
ZZP intake tube with K&N filter
ZZP Alternator spacer
ZZP idler stand with idler pulley
Valve cover breather
Bosch IC pump & mounting bracket
ZZP S3 heat exchanger
All nuts, bolts, gaskets, fittings, and hoses needed
Instructions with pictures on a CD
and you can buy your own sc and lim and upgrade to 60# fuel injectors
Yep, as long as they have a good bolt selection - a few are "oddball". Stores by me have em.
So is it really worth it to spend all this money to supercharge??
haha yeah the tune but everything else is complete correct? Hopefully i'll do it at the end of next summer, but what injectors should i get? it says it comes with 39# injectors. should i upgrade to the 60 for 75 dollars?
depends how much boost you wanna run and what size pulley.. Im doing 60# injectors with 2.8 pulley..39# injectors are basically the stock injectors that come in the SS/SC
oh alright. since zzp hasn't come out with smaller pulleys would it still be fine if I run the 60 or will i have to upgrade both the pulley and injectors at the same time? haha i'm such a noob when it comes to sc
