Car died as i went to start it back it wouldnt crank. Towed to dealer was informed it needed a new ignition switch replaced switch still nothing When i turn the key on no lights show no check egine to show pcm is on nothing at first i was getting the security lock did a key relearn it still comes on when the key is turned on but goes off within a couple of seconds checked all fuses all relays all good Had the problem with the shifter knob and the key not turning all the way back removed bent rod in shifter used a wire tie on the key solenoid to stop it from locking the key in on position What else could be wrong ?How can test me pcm to verify it is bad?
Chevy Customer Service
roach203286 - would you please send me a PM with your VIN so I could look into this for you?
Thanks,
Laura
GM Customer Service
