Well I was having an issue with my cobalt with no lights turning on the dash what so ever and the car would not start. Went to the dealer. Took them a full week I guess the fuse box was bad and fried them rock and tcm. Got a new battery, a new fuse box, a new ecm, and a new tcm. Drove it home and to work. Took it to work the next day and half way there it started having all these signals go off at once ?low fuel , power steering, ect? Even the security light turned on for the key. I turned it off and turned it back on and I got to work normally. Got to work fine but the check engine light stayed on. It drove normal. Tried to start it a day later and the engine will not crank at all please help. The engine seems fine. I pushed in all the fuses and relays as well. All the fuses are brand new
Looks like the dealer you brought it to screwed you over. No lights in the dash is how your Cobalt warns you that both your tail lights are burnt. The BCM has a sense resistor on the voltage line going to the rear. If it senses no current load when lights are suppose to be ''ON'' it turns ''OFF'' the cluster lights to warn you that you have no tail lights. I would bring it back to this dealer that probably charged you an arm and a leg and tell them the parts they changed solved nothing.
Well they got my car running, which would not run before. I ended up paying $1500 for the repairs and got a 12 month warranty. All the lights on the dash still turn on now. It just won?t crank at all
sorry I?m new to the forums and I?m just so desperate here
