1 - 1 of 1 Posts
Description:
Excessive heat can cause resins in your brake pad to vaporize or "outgas." As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance. Here's where Power Slot's slotted brake rotors make a big difference. Power Slot's exclusive Vac-U-Slots are machined into the rotor and help evacuate gasses and dust, shed heat, and keep the brake pad surface clean. And in wet, raining conditions, our Vac-U-Slot helps push water off the braking surface for better stopping power. A combination of Hawk® high performance brake pads and Power Slot slotted rotors will deliver superior, reliable braking for virtually all automotive, truck and SUV applications, even under hard driving and severe duty conditions.
Store Link:
Never Enough Auto 877-609-6727 - Saturn :: Ion :: 03-Up Ion :: Performance & Power :: Brakes :: Brake Rotors :: Powerslot Front Premium Slotted Replacement Rotors #8239
1 - 1 of 1 Posts
