1 - 9 of 9 Posts
Anyone have a problem with the install of a K&N Tycoon? I installed one on my '09 2.2l (Auto) and the heat shield rubs on the engine and behind the headlight on the frame. All the other pictures I see look like they fit fine and have plenty of room.
I dont know about the K$N Tycoon but my K$N Typhoon went on just fine.
mine came loose after a while.
you might just be able to bend the mounting brackets a little to get it off the mount.
The brackets are pretty adjustable. I also put a little rubber pad under my heat shield because it vibrated on the motor mount a little bit.
1 - 9 of 9 Posts
