1 - 20 of 29 Posts
I went to my local autozone and purchased all of the parts that I was told I would need to assemble an intake. However, when I went to put it on the car, it seems that the MAF sensor does not fit into the part that I bought for the car. Has anyone had this problem, or can anyone provide any suggestions to solve this?
I had to dremel a horizontal slot on the intake. You also have to make sure that your MAF is facing the right way.
reference this man
http://www.yourcobalt.com/forums/engine-mods/11823-everyone-may-want-make-there-own-intake-should-help.html
I was hoping that by buying the MAF sensor adapter that spectre makes, I would be able to get around the dremeling
I take it there's no local store that would carry them then?
I wouldn't doubt they have them, just find a person who can make clean welds and your set.
yeah i did the same thing. the part from autozone doesnt fit. just dremel the slot push it in and you're good to go
i would do it to a new piece
And that is why I spent the money and got a K&N Typhoon intake. Fits right, right out of the box.
On AutoZone.com you can order part #9405. It has the correct adapter and is a perfect 74mm on the inside of the tube so your Cobalt will not throw a code. Check my garage for the pics. I also used the P3 filter #9132.
Hope this isn't to late to help.
What size reducer do I need for my intake?
---------- Post added at 05:44 PM ---------- Previous post was at 05:42 PM ----------
and what size strait pieces do I need
I left the stock box...and apparently my car runs pretty good from the times I have seen here. It was stock at the time too...most new cars don't like having the MAF disrupted from its factory location...I used a reducer from the stock box to a piece of leftover intercooler piping my buddy had from his DSM build...and ran a 90* Silicone coupler to the TB. Then I yanked out the bottom of the air box and hacked the car out of it pretty much exposing the entire bottom side of the K&N Drop-In I have. Probably does just a good of a job as the $300 intakes do for ~$50. Pic of it is in here...
http://www.yourcobalt.com/forums/engine-mods/20872-exhaust-video.html
Don't think you can beat using the stock airbox...I bet mine flows just as good as that K&N :D LOL
reason why i got a K&N bc i know it would work right outa the box
1 - 20 of 29 Posts
