1 - 19 of 19 Posts
Sorry if this is already discussed in a previous post, or if it's in the wrong section, but I've been having a problem with some projector HID's that I bought from CarID.com. Some people have mentioned in the past that one might want to go for higher quality, but alas, I did not heed their warnings. I understand that they've also stopped selling them on their website. Is this because they were getting so many complaints and had to stop selling them? If that's the case, am I entitled to a refund or anything of that nature? My passenger side light has gotten so dim, I get pulled over because the officers think it's completely out. A VERY close inspection will show that it's still somewhat on, so I get away with it 9 times out of 10. Don't exactly have the cash to throw at an entire new set of lights either. Has any one else had these issues?
Mods: Feel free to move this thread if it's in the wrong section.
Just look local for a set of used oem headlights, Shouldn't run more than 60/70 bucks and just throw those on your car and you'll be good. But if your set on keeping them then do a good job checking all the wiring and connections to check for bad wires or bad connections which might be causing the light to dim.
You won't know until you ask. Are we talking bulbs or housings? How old?
CarID is one of our vendors here, I believe, and would do well to honor any legitimate refund/exchange requests. If they don't offer a solution that meets your satisfaction, then you have more aggressive options. But give them the opportunity to fix a mistake.
Everyone has their opinions, but I found the set I got from theretrofitsource to be excellent quality. Price tag wasn't too bad either.
FYI I have a set of brand new 4300K H7's (Morimoto3five's) sitting around if they fit and you want to buy. They're my spares, but I'd let them go cheap to help you out.
Well I appreciate that Stratos, but I'm using 10000k H1 bulbs.
Here's what I have:
SPYDER® - Smoke CCFL Halo Projector Headlights
NOTTO® SE - Complete HID Conversion Kit
Options: Color Output: [10000K] - FACTORY SKYLINE
The bulb or ballast on the passenger side has almost gone out completely. They stopped selling the kits on the website and I just spoke to a customer service rep over the phone. They'll be issuing me a $60 refund, which is partial considering the kit cost a little more than $100. I'm glad they were able to give me something back, but I feel as though they should have done more to correct the problem. So now I can buy a new ballast and bulb, but it's going to be a different ballast and that in itself is a problem for me. You start mix matching things and that's when you get problems. Their customer service team is excellent, don't get me wrong, but they chose to stand behind a sub-par product but, and this is strictly my opinion, they don't seem to be willing to take the full blame. My parts were still within warranty, they have two months left. So now I've got a jerry-rig solution to work with, unless I want to fork up the cash to swap out both ballasts and bulbs, which is more work than I really wanted to do.
I don't feel neglected by the customer service team, I just feel ripped off by the quality of the product and how little the company is actually able to do to remedy the situation. Ugh, first world problems.
Easy solution. Flip your "good bulb" over to the side that is dim. If the bulb displays dim than you know it's the ballast. If the ballast is bad and you litterally bought them brand new recently I would demand they send me a new ballast, which they should have. If it's the bulb, unfortunately a lot of factors go into that which many of them would be your fault so I would be content with $60.
Remember that CarID is just a distributor and not a manufacturer so they aren't going to stand behind someone elses product 100%.
So, when did you buy and did you get this as a package deal or did you get the HID's, conversion kit, and housing seperately?
It was a package deal and I got them around 8 months ago, maybe less. I'm going to try swapping it over but to be honest, I had a mechanic hook them up because I haven't got the slightest clue when it comes to cars aside from airing up my tires and checking / changing fluids. Very basic maintenance, nothing more. It's my understanding that there's a whole heap of crap you have to do to remove the headlight housing, but I haven't looked into yet. It looks like I'm going to have to remove the front grill, not sure though. I'm going to try this when I get home if it looks like something I can manage. I'm pretty sure I haven't done anything to cause a problem with the bulb, as I know the wiring and such is all 100% correct. I had a very long-time family friend who is also a certified mechanic install them. Plus, if the passenger side is a direct mirror image of the driver side, wouldn't both bulbs have problems if it were a direct result of something I did? Keep in mind, when it comes to moving parts, I'm clueless. I'll gladly work on some one's computer for them if they come fix my car :p
Just kidding on that last part. I'm looking up tuts to remove the headlight housing now.
no man, two bolts and the whole thing slides out, no joke. Its that easy. Now the wires that they probably used scotch-loks to hook up, they'll be your problem.
Well, you typically have to remove part of the front bumper to completely remove the housing. FYI
Things like turning your lights on and off a lot or touching the bulb with your bare hands can negatively affect the life of a bulb. I'm sure there are other factors but these are the two big no no's
---------- Post added at 01:59 PM ---------- Previous post was at 01:58 PM ----------
Show me two bolts to remove the headlight. Never heard that or gotten it to work properly without messing up the bumper before.
no problem, when I get home I'll take a picture. My car and my friends g5 come out the same way. Undo two bolts and wiggle out the light. We did my hids and his in 15 minutes.
---------- Post added at 04:03 PM ---------- Previous post was at 04:00 PM ----------
i stand corrected, you need to remove one little press in tab where the top of the bumper reaches the rad support.
Discussion Starter #11
That'd be great Money Man, because as Blackbalt said, I've only ever heard of people having to remove their front grill in order to remove the headlight housings. I know of the two bolts on top that you're referring to, but I've read that there's more to it than that.
I got my stocks out that way but cant get my gen4's back in that way.
hmm, not sure on the aftermarket, both of ours are stock. Mine are aftermarket oem style and his are factory. I didnt think that'd make a difference.
I took my stocks out the same way, but when I tried putting the gen4 back in that way the lip on the front wouldn't slide under the bumper. I almost cracked it trying to get it in. Finally I just took the wheel well half out and detatched the bumper to get it to sit right.
hmm, only thing we had to fool with was the alignment tabs on the bottom of the headlight but they slide right in with 10 seconds worth of work.
yea that was also my biggest pain when putting my lights back on, i still dont think they are sitting right lol
Discussion Starter #17
So it sounds to me like the 60 bucks they refunded me was half for parts, and the other half for the insane amount of b.s. I'll have to endure just to switch them out. Le sigh. Looks like I'm forking up another labor bill because it doesn't sound like a simple switch and play operation. This kind of stuff makes me wish I had never started modding my car, but now I'm just on the ol' U.S.S. Self-Pity.
Jack car up, take off wheel, take out wheel well screws and some trim screws, take out four bolt holding bumper to fender. Done.
Discussion Starter #19
Thanks Blackbalt, but if I were to do as you said, I'd be left with a 3-wheeled car. Of course I know I have to put the wheel back on, my point is that I would have no idea what to do after I get the wheel well off. I just hate how much crap you have to do for a simple fix like this, caused by one company peddling some one else's sub-par crap. But I guess there's nothing I can do about it now except move on. Thanks for the replies you guys.
1 - 19 of 19 Posts
