1 - 11 of 11 Posts
I know there is a thread of how to and I know where it all goes, but the trouble I have ran across is that my reading on my gauge is 10.0 and sticks to rich, no matter what rpm i am in and throttle response.
It has the following connections: 1 wire to signal (t-tapped to circuit wire 1355, purple/white), 1 wire to ground (chassis mounted with a screw), 1 wire to Ignition switch wire red/white (constant power), and 1 wire to accessory power (Ignition switch brown wire). Any help?
Levee
Wideband or Narrow?
Did you calibrate it? Used? I'd lean towards a bad sensor.
You can't calibrate it. PCM controlled. Wideband. Lap uses wideband. I tapped into low signal wire. May just go with an autometer. Narrow band is ancient in today's cars lol.
Really are you sure LAP has a stock wideband? I'm pretty sure it doesn't. Which would explain the constant reading.
Levee
If I remember correctly only the LNF came with a factory wideband.
That's what I thought
I don't think the LAP has a factory wideband either.
Your right. It has a heater circuit. Signal, power, and ground. I tapped into the wrong wire. Thanks alldata for incorrect wire diag lol. Its gray
So it's not a wide band and you tapped a constant voltage?
1 - 11 of 11 Posts
