1 - 13 of 13 Posts
One of the rings in my halos is out, checked the wiring and it looks pretty solid. Not sure what the issue is -_- sorry if this is in the wrong place
Sent from AutoGuide.com App
what generation headlight are they? my cobalt had Gen1 projector headlamps and the L/S halos weren't working the wiring looked great but the halo's in Gen1's are actually LED powered at the base and light tunnels make up the halo, I pulled the grommet underneath (where the halo wires go INTO the housing) and then got direct access to under the halos, turned out the LEDS were burnt out, so I soldered some new ones in and they worked great after that.
I'd check that out if I were you if you have aftermarket headlamps.
1 - 13 of 13 Posts
