1 - 16 of 16 Posts
Like the title says, my radiator hose touches my intake no matter what i do(hood pushes it right down onto it when i close it. Anyways, i just notice that the longer tube on my intake heats up quite a bit(see pic). Im just wondering how this affects performance compared to it not touching...
Might i also add that since i installed my intake, my coolant temps will raise up a lil faster, but they will also fall just as fast too.
should be no big deal unless it kinks the hose. may soak a little heat from the coolant into the intake but no biggie.
****thread jack alert****
dude your back?
Discussion Starter #6 (Edited)
Its not changing the form of the hose in any way, so im glad to hear theres nothing wrong. Now another question relating my intake. Ever since I put the breather filter on my SAI, i have been getting a CEL. Could this be because the diameter of the filter is about half the size of the stock one? I figured the fact that the filter was high flow might have balanced that out.
filter? what? there's a pcv hose that goes to your intake. this is to create suction in your valve cover to compliment the positive pressure caused by windage and blowby. it's pretty intricate, but basically you NEED you make sure all of your intake couplers, pcv hose and everything are air tight past the mass airflow sensor or you will get a false reading and most likely a rough idle.
Everything is air tight, im talking about the SAI tube(cant be seen in the pics) I put one of the smaller spectre breather filters on it. But that is now gone(somewhere between here and california lol, lost it on the trip sometime :p ). Anyways, i hear that the CEL may be cleared up if i unhook my battery for 15 mins. Im gonna try that tomorrow.
soooo you blocked off the nipple for the hose, right? you can only put a breather on the valve cover, and i wouldnt even recommend that with an n/a motor
I know spectre carries a larger breather filter that can fit over the SAI tube instead of being plugged inside of the tube. Im definitely gonna do this because I dont want to leave my SAI tube unfiltered since it was filtered with the stock intake.
Discussion Starter #12
Dont worry, its not imaginary. It was pushed down a lil. I just got this filter for it and it holds in there great.
OH...oops I'm embarassed lol
i thought you guys were just using some different term for pcv.
sai would be that air pump nonsense. thank god i dont have that stuff!
1 - 16 of 16 Posts
