Hello, really need some help. When I turn my car off everything goes off as it should except the radio lights, just the lights stay lit the radio goes off and doesn't play any music the dome lights go off as well as they should. What could cause just the radio lights to remain lit? If it was a bad door switch I would think the dome light would stay on too.
Could I take the power wire from the radio and relay it to a different fuse in the fuse box using a fuse tap? when I take the radio fuse out the radio lights go out so maybe it's a problem with that fuse?
Something in the radio is probably going or has gone bad. It probably has a micro relay that is staying on. I have had similar issues on my Mercedes. The relay in that stereo was able to be removed and replaced.
Also which stereo do you have. Does it have the amplifier in the trunk? If so that could be related to the problem.
