1 - 9 of 9 Posts
alright so my radio stopped working the other day for some reason and the door chimes and everything i changed the radio fuse and others as well and was wondering if nebody knows any solutions.I still have the stock radio in if u needed to know..please help greatly appreciated.
If your radio isn't turning on, as in zero display. It might be bad... Did you check the fuses under the hood??? The reason your door chime isn't working is because of the radio not having constant power or by just being defective. You will also notice your light and fuel chimes are gone, along with seatbelt and just about anything that dings.
If you go aftermarket you can buy a can-bus box that will bring those chimes back to life. Generally a pricey add-on to an aftermarket install. If you don't mind losing the chimes, enjoy the blessing and buy a nice new radio. You will be happy. 16-18watts rms, is alot smoother sounding than 7.8-9watts rms, from your factory headunit. Your factory speakers will come to life.
but thats only for the radio i couldnt find nething on the chimes and couldnt find the under the hood fuse..ne help
The chimes should be tied into your radio so the radio fuse should have taken care of them if that was the problem. Are you under warranty still? Take it to the dealer!
yes no radio means no chimes.... If you go with an aftermarket radio you would need this
GMCOL11 It will create the chime if you replace your radio. There are no chime fuses in these vehicles.
yea its still under warranty so im gonna take it back.im just gonna pull my system back out.and yeah i have an 07
1 - 9 of 9 Posts
