1 - 8 of 8 Posts
I'll be driving around and randomly the "brake" light will come on, the light that's in the cluster used when your e-brake is engaged....it stays on for about 20-30 seconds then just goes out.
any ideas?
i checked my haynes manual an said to check fluid level first if not already done then check all wires&harness after that it doesn't say much, for the fact that these manual are not as helpful as they used to be.
I just put new pads on today, so checkin the master cylinder wouldnt be a bad idea....thanks guys
If it was a fluid issue, your DIC should say "BRAKE FLUID" in conjunction with flashing the brake light.
1 - 8 of 8 Posts
