1 - 9 of 9 Posts
I have the same issue. I have changed the shocks but it did not help. I am thinking it is some bushing somewhere in the rear suspension but I have not been able to determine where. I had a similar noise in the front and it was the bushings in the lower control arm. If you find it I would like to know.
These cars have a beam axle as a rear suspension. It has two large bushing that attach it to the car frame. The bushings occasionally dry rot and become loose. So that will be where to start looking. If the car has a rear sway bar, the bushings on it and the end links should also be checked.
Cody is right about the rear beam bushings, they could be shot. Also it is not unheard of for the rear coil springs to break on the bottom side of them, that could also cause a rattle. The rear shock being bad wouldn't normally cause a rattle, it would more than likely just make the rear of the car more bouncy. You can also check heat shields and things underneath possibly rattling off the underside.
The cobalt does have rear sway bar, but it is welded to the rear beam.
I also had replaced the bushings springs wheel bearings an shocks. Still rattles on drivers side an EVERYTHING is tight??? Thinking of having someone weld the sway bar in on the corners a little bit more just in case it’s broken there but it’s tight.
2008 Cobalt LT & 2008 Cobalt LS
Is it possible to do the rear bushings without the "special tool" or is there a Harbor Freight version of the tool that works?
I just used a pipe for exhaust an pounded out the old one an put the new one in same way. But it didn’t stop the rattle
1 - 9 of 9 Posts
