OK here's the problem. Will crank start for sec but wont idle will die. Everything has been replaced including supercharger m62, maf sensor,map sensor,crank shaft sensor,can shaft sensor, fuel filter, high flow performance fuel pump,60# fuel injectors new,new spark plugs and coil packs, new intake manifold,new intercooler and pump,egr new, throttle body new, timing been checked, compression test done, fuses and relays replaced, the computer was tuned by the people whobive bought the supercharger kit from which zzp performance, etc.. So I'm already over 3k put into this and still not running so any advice is very appreciated oh and its throwing no codes I've used a obd 2 scanner and a HP tuner scanner, reply or email deathawakening09 @gmail.com and can even give my number but privately.
Have you tested for fuel pressure at the rail? Was your old fuel pump dead - why switch to the high-flow fuel pump (it's not needed until you're into something like the 400+ HP range).
