Hello everyone, I have a 2006 Chevy Cobalt Ls and I love it so much. My dad gave it to me and it's my first car I've ever owned so it has a lot of sentimental value to me. I recently installed a rear axle with disc brakes on it and now I'm having an issue with the brakes where I have to almost slam them to the floor in order for them to engage. I replaced the brake fluid twice, replaced the master cylinder and even adjusted the e brake but the brakes are still squishy. I don't have ABS if that helps solve the problem. But any help would be greatly appreciated!
You may need the proportioning valve from the disk break car and you may still have air in your system.
Really? How would I use the proportioning valve if it's an abs module? Can you still use an abs module without sending power to it?
You just wouldn't use the ABS module - it'll make your life significantly easier, though, since bleeding those can be an absolute nightmare.
But yes, you need the disk/disk proportioning valve, as drums require quite a lot less pressure than disks, so this is throwing the overall system pressure off a good bit.
That said - if the pedal is squishy, there is definitely air in the system somewhere. What is your process for bleeding it?
Use this procedure
I did on all of my 5 cars it works great,
Thank you for your reply MP81! Turns out I had the front calipers on the wrong sides which trapped air in it because the bleeder valve was upside-down... Fml lmao
