1 - 20 of 34 Posts
yeah first make sure the tires dont say maximum pressure 44 psi lol. if its just 44 psi recommended definitely trust the tires over onstar
44 seems mighty high...mine are filled to 35 pounds
Always go with what the tire says.
Forget BOTH, especially the tire sidewall. The sidewall states MAXIMUM pressure the tire is rated for... Go to GM tire pressure label visible when you open your left front door. This will tell you the recommended tire pressure for YOUR car. Pressures are quoted here when "cold." Cold in this sense means check tires first thing the next day after car has sat overnight or 4-6 hours after last driven. As you drive, the tires warm which will increase their pressure, thus giving you an inaccurate "cold" pressure reading. Check your owner's manual to verify this information.
The XFE may have specific pressures to maintain its fuel economy status.
Forget BOTH, especially the tire sidewall. The sidewall states MAXIMUM pressure the tire is rated for... Go to GM tire pressure label visible when you open your left front door. This will tell you the recommended tire pressure for YOUR car. Pressures are quoted here when "cold." Cold in this sense means check tires first thing the next day after car has sat overnight or 4-6 hours after last driven. As you drive, the tires warm which will increase their pressure, thus giving you an inaccurate "cold" pressure reading. Check your owner's manual to verfy this information.
Couldn't have said it better. Great post!
i run mine 32 in the front and 38 in the rear
I agree with all of that except the GM label...those are for the stock tires/tire size only. For a passenger car low 30's is a good mix on comfort/control and fuel economy...I keep mine at 32 warm.
I agree with you, I go by what the GM recommends when I am running on stock size tires, but when I am not on stock tires I go by what the tire says, but a few psi less.
exactly. mine is 35/35. But I have a question. Shouldn't you fill them like 2-3PSI under recommended? Cause when the tires warm up, then their 2-3PSI over....
you run 32 in front and 38 in back. never heard of pressure like that. is there a reeason for off set pressures?
maybe he street races a lot :laugh: lower pressure on fronts higher in back for FWD
1 - 20 of 34 Posts
