1 - 8 of 8 Posts
Has anyone installed a remote start on there balt themselves and how hard is it. And what is the best bypass module for these cars. By the way I have an 09 cobalt Ls
Sent from my SPH-D710 using AutoGuide.Com Free App
I got the ls with power nothing I just got done installing power door locks and a alarm but it also has remote start and I wanna hook it up
I have the remote start but idk what bypass module to get
I just installed mine thanks to the help of a few members on here.
Bypass I used is the Idatalink ADS-AL-CA with the GM2 firmware. You can also get a xpress bypass kit, their website tells you which model you need.
on the Idatalink.com website it lets you put all the info in and it will tell you exacly what you need. Mine was an 05LS sedan.
---------- Post added at 10:50 AM ---------- Previous post was at 10:49 AM ----------
iDatalink - Search
heres your choices for ADS modules.
---------- Post added at 10:54 AM ---------- Previous post was at 10:50 AM ----------
as for wiring the starter yourself. its fairly easy.
If you use a remote starter with a datacable (mine was prostart, here in canada) you just have to connect maybe 10 wires in total from the remote starter and the bypass. (a few you have to connect together then to the car, ex... accessory from remote starter ties to bypass and then to the accessory wire in steering wheel.....but it really isnt too bad.)
P.S. make sure you get the bypass programmed for your car, with the correct firmware(GM2), and the remote starter youre using.
---------- Post added at 10:55 AM ---------- Previous post was at 10:54 AM ----------
Youre more then welcome to PM me with any other questions.
1 - 8 of 8 Posts
