Hey im trying to remove the strut from the wheel assembly im trying to figure out how to remove the two bolts from the knuckle on the wheel assembly to take off the strut... those bastards won't budge are they threaded or just go straight through because i can't get them to move
It's a splined bolt, do not wrench on the bolt head, only on the nut. You will strip out the splines if you wrench on the bolt head.
