Member Rating
  • 1/5
    Votes: 0 0.0%
  • 2/5
    Votes: 0 0.0%
  • 3/5
    Votes: 0 0.0%
  • 4/5
    Votes: 1 100.0%
  • 5/5
    Votes: 0 0.0%
1 - 1 of 1 Posts
Manufacturer Part Number: 62.0430
Application: 05-Up Cobalt & SS
MSRP: $199
Description:
Progress Technology Anti-Sway Bars reduce body roll and improve chassis response for more cornering power. Anti-Sway Bars are precision-formed and powder coated (graphite color) alloy steel. Polyurethane bushings produce instant roll response on turn-in and have been tested at over 1.0g lateral acceleration on the skid pad.
When one side of your vehicle's suspension compresses, or pushes down on the springs, the anti-sway bar is pulled up. The resulting twist in the bar forces the other end to pull down. This force will lift the compressed corner of the vehicle and pull down on the unloaded wheel on the other side. The result: your vehicle will lean less and handle better and more predictably! You'll have better control when maneuvering through lane changes and tight turns! Each bar is manufactured from high carbon steel, hardened, and stress-relieved. Includes lifetime limited warranty!
* Gives Your Vehicle Flat, Tight Cornering!
* Balances Out Understeer!
* Provides Dramatic Handling Improvement!
* Lifetime Limited Warranty!
1 - 1 of 1 Posts
