For some reason, the new headlights I purchased keep blowing the 10amp lowbeam fuse, I checked the pinning on the harness, it was wrong, so I repinned the lights harness, yet it still short out. I can put the fuse in the car, start it up, then its fine, its the second time I start my car that it shorts out every time..only the lowbeam on the pass side..should I put the DRL fuse back in or what?
Sneezing Daily
What kind of headlights are they? Check your ground... as well it could be that, check the pinning on the specs to see how it should be... just double check everything?
Stock headlights, I haven't checked the actual wiring but im half tempted to tap the ground and ground it to a frame bolt.
mustbe a short somewhere. take a test light, put ur headlights on and see what u get a positive from. those are the low beams there should be 3 pins in think. trace that wire back, must have just been a short
