· Registered
if I remember when i did mine that splined shaft should come out. It's about six inches give or take, connects the cv joint to the differential. looks like this.
2005 CHEVROLET COBALT 2.2L L4 Output Shaft | RockAuto
The seal you're trying to take out may be a repair sleeve, this.
pull out the stub shaft/output shaft is what rock auto calls it, then press off the repair sleeve if it's too damaged and get a new one. It's a very tight fit, have to be careful putting new one on. And if the seal you bought did not come with that, I'm not sure about all the sizing and compatablility of repair sleeve and seal.
