1 - 8 of 8 Posts
2 bolts on the floor in the back then slid it out. You will be able to see very easily how to do it when you take the bolts out. Be careful though you also have to remove the airbag sensor wire before it comes out
The sensor is on the bottom of the seat and the wire comes up and plugs into it. I believe a small flat head is what I used to unclip it
Yeah, it is pretty easy. Be carefull tho, if you are trading seats of 2005-2006 to 2007+ you'll have to swap passager underseat frame. 2007+ have sensors on both passager and driver. 2005-06 only driver. Easy removal but still gotta do it if you want to still have your passager airbag working.
My '07 doesn't have anything under the drivers seat...
1 - 8 of 8 Posts
