my car had the code of p0411 and shop says it is the secondary air injection, new it is $260 and the only used one i found was sold out from under me 30 minutes before i got there to pick it up(my husband called yesterday to get and they said they would have it removed today) they wouldnt take his name tho. it is a 2007 2.2..any ideas on a used 1 close by. nw iowa
check pamsauto.com I've taken a few parts off cobalts and HHR's they have sitting around there and its in MN so shipping wouldn't be much
i had this problem a couple of weeks ago,this is what happen to my car: first the pump went an when i pulled it out it was full of water so i replaced it then the diverter valve went which runs the pump. if u drove through any puddle's lately try to pull it off an drain all the water an then plug it back in an see if it works. if u know anybody that works for a dealership u can get it for half price,my father works at a GMC dealer so i paid $109 for the pump an $137 for the diverter valve. oh yah i took mine to the dealer first an they tested the pump an told me it was the pump after i replaced it the light was still on so i took it back an they tested it again an found that it was the relay that runs the pump which is part of the diverter valve. hope this helps
2007 LTZ code p2440 says secondary air intake clean it or replace it $260 new and not available in auto parts stores yet. CLEAN IT its easy.
Make sure your sai tube is connected properly so there is No air leak
Sent from my SCH-R720 using AutoGuide.Com Free App
