1 - 10 of 10 Posts
None if they're all working.
You don't need to run 89. You could replace some gaskets, clean your throttle body and get a k&n drop in filter, run some injector cleaner, seafoam your intake. All that is cheap and if it doesn't add any mpgs, it'll at least clean everything out
Plus its winter. If you are doing any city that's about right. 34 with mostly hwy was what I was getting stock.
You should notice a mpg difference with 87 compared to the 89 you're running now
yes i most curtainly do..
another random question?
do all fuel pumps on my type of car shuts off at 112 MPH?
This engine cut-off is set according to tires that come standard with the car. Tire speed rating is the criteria here for top speed cut-off.
1 - 10 of 10 Posts
