1 - 18 of 18 Posts
I recently replaced a turn signal module on my 2007 Cobalt LS. The swap worked fine - but, now I have an indication that my air bag needs servicing. Is there any wiring in the steering column I could have disturbed, that is implicated? I took it to Auto Zone to run a code, but it came up empty - no code found. I tried disconnecting the negative terminal of the battery for a few minutes, to no avail. Not sure what else I might be able to do, to further diagnose.
Thanks
Dan
What do you mean by turn signal module?
---------- Post added at 07:05 PM ---------- Previous post was at 07:04 PM ----------
Turn signal lever maybe?
Yeah that's the lever, but I don't think you can disrupt the airbag wires by changing the lever. Airbag is separate harness that runs to the clock spring. Could be one of a few things. Regular OBDII readers won't read ABS and SRS codes, you need a TechII or similar reader. Lots of times it's the passenger presences seat switch where people clean under the seat and inadvertently disconnect it.
---------- Post added at 09:23 PM ---------- Previous post was at 09:22 PM ----------
Check that first.
Ah! So, the complaint could actually be coming from the passenger side... OK, will check the connectors. Any harm in disconnecting/reconnecting for good measure?
Thanks for the tip
Dan
Nope should actually do it a good cleaning.
---------- Post added at 10:14 PM ---------- Previous post was at 10:13 PM ----------
That is the most common issue but it could be any one of the sensors.
  • Like
Reactions: Parthros
OK, finally getting around to checking the under-the-seat connectors. I disconnected, and snugged up real well; still, the indicator is on.
It seems to me a remarkable coincidence that I (successfully) replaced the turn signal lever - by taking apart the steering column housing as described here - and this indicator came on. At any rate, what's the next step in my diagnosis?
Thanks
Dan
Did you check the airbag fuse? fuse 13 in BCM fuse block.
Front impact sensor under the hood??? Not a lot to it in the 2007.....
Discussion Starter #12
Where is it, and what is the procedure for checking it - something I can do with a VOM?
Is there a diagram of the circuitry? If it's seat related, I'm wondering if there is something I can jumper, in an attempt to further diagnose.
...and if there are wires going to the airbag in the steering column - and, I was in the steering column fixing the turn signal lever when this all started - I am still hard pressed to believe any other failure happened coincidentally. But hey, what do I know about Chevy Cobalts? Nothing.
Did you remove the air bag? Or you just worked around it.
The front impact sensor is mounted in the middle of the rad support. Facing the engine.
Discussion Starter #14
I just worked around the airbag.
How do I check the sensor? Is it a N/C or N/O open switch, do I check it by removing the connectors and checking for continuity?
Kinda need a TechII to check it. But you could always check it for corroded contacts.
Discussion Starter #16
This guy, right? Sorry for being fuzzy, I couldn't get a shot of it further away.
It looks like it's got a tamper tie-wrap on it, so I'm not sure I can check the contacts for corrosion without cutting it - and if that's advisable.
I'm back to the seat(s): Are these N/O contacts, that are supposed to close when you sit in them - and, possibly, they aren't? If so, could I rule them out by jumpering the contacts (just for diagnosis)?
Apart from (re)taking the column shroud apart and inspecting, I'm not sure what my next step is - except, perhaps, to take it to a specialist. And that, as we know, will involve some serious $$. I was hoping to avoid.
Dan
Find somebody with a TechII or full optioned Snap-On reader and get the code read. A lot of cheap readers won't read SRS or ABS codes.
1 - 18 of 18 Posts
