After washing the car, I was backing the car into the garage to dry and noticed the warning along with the lights. Whats up with that? Would that happen in the rain, or if I driving in the snow? Would this be covered under the drive train warranty?
Did you use a power washer? Let it dry it will go away on it's own. Moisture probaqbly got into a connector.
Just a regular garden hose. I just got back from the garge to start the car and just the abs light is on now. Might be moisture like you said.
Yep! One of your ABS sensor connectors is probably wet. You could disconnect these spray some contact cleaner then add a bit of dielectric grease to keep the moisture out. Maybe one of the rubber seal is cracked or missing.
