1 - 9 of 9 Posts
I just got a recall notice in the mail today for our 09 cobalts........... :mad:
It says:
09041 shift lever indicator may not display correct gear.
I haven't noticed a problem (yet) but then again I don't usually look at the shift indicator. I really don't think it would ever be an issue for me, but I could see my wife not paying attention and think its in drive because the indicator says so when its really in reverse.
So it looks like after only having them for a month they'll already have to be going back to the dealer........... Hopefully this isn't a sign that I'll have TONS of problems like I did in the 06 G6 that I traded in for my cobalt..... I guess we'll see.
Does anyone know if it only effects certain models or???? I'd hate to take the time off of work to drop off 2 cars at the dealer and have it turn out that they aren't effected.............
Talk to you all later
bye
My friend had so many problems with his 06 G6 gt he ended up trading it in for a Dodge. They only gave him 3700 for the car and he owed 13000 But he didnt care he was tired of the cars issues. Hopefully everything works out with your balt. P.S. Dont park behind your wife :p
Yeah I bought an 06 G6 V6 4 door brand new and babied the car and had tons of problems......
After having it about 6 months the problems all started...... Reflector fell off of the door and broke, light on fog light switch stop working, all the bolts in both front doors were coming loose, the drivers door actually came un aligned and started leaking water, and the radio stopped working.......... They fixed all that stuff.......
Then it kept over cranking when you started it a couple months later. They reprogramed it and it didn't do it as much but still would occasionally till the day I sold it......... It actually did it the last time I started it at the dealer before I traded it in.
Then a couple other smaller things here and there.
Then TONS of steering clunk problems....... They replaced the steering column, and it started doing it again the very next day. I bought it back they said it was another bad column but had to order one. A week later they got it in so I bought the car back in and they told me that they "just" forgot to tighten the bolts on the column........ :x After that it still didn't fix it so I called and filled a complaint with GM............ After another column, tie rod, and a lot of BS I found a service bulletin for the exact problem. They tried it a couple times and that didn't work either......
Finally told GM I called the BBB and my lawyer was going to be calling the next day (I just made that up at the time LOL) they finally said to give the dealer one last chance and they'd send a tech up to look at it with them. They replaced the steering gear and it finally went away. I know this was partially due to a crappy service dept. (btw don't ever go to Neil Norton's in peoria, IL)
Then my speedo and gauge cluster would randomly turn from MPH to KPH. I took it to the dealer and they "said" they couldn't find a problem, but it never had a problem after I took it in.
Then about 6 months after the steering clunk, it started again, they said that every 20000 miles or so I'd have to spray grease on the intermediate steering column.
Then a few days before my warranty went out I started getting a clunk in the drivers side front end whenever it was cold out............ I took in into the dealer several times and they couldn't hear it..... Turns out they'd leave it park inside in the warmth all day then look at it......... EEEERRRR THey finally hurd it but couldn't find a problem.......
Then a month ago @ about 72,000 miles a front wheel bearing went out. At this point I was just pissed off at the car and that same day I got an email from my GM car saying I had a grand built up on it to use towards a new car.......... I was hesitant to get another GM, but I've always been kind of a GM guy, but I couldn't pass up a brand new cobalt for $9500 before taxes.........................
Like I said hopefully I have better luck................. Or It will be my last gm... LOL
Talk to you later
bye
sheesh everyone has so many problems but i dont have any
My 09 starte having this shift indicator problem two months after I bought it. It shows it is stuck in between reverse and nuetral or something like that. I bought it in September but I haven't bothered to get it fixed yet, it's not that big of a problem.
1 - 9 of 9 Posts
