2005 Cobalt 2.2 w/auto in base model, (178k on motor) while driving I stopped on side street & put in reverse to back up and engine died.
Only spun over, towed it in.
Tried a small spray of quick start, to try to fire it up, no start.
What is the easiest way to check the timing?
Can I check the timing without taking it all apart?
Thanks, Tim
Does it spin faster than usual? If chain breaks then it doesn't turn the cams so it spins faster. Or you can just take the cover off
