That's Mr. meogE to you.
UPDATE: The shifting problem was caused by a bad master cylinder, in case anyone was curious.
I have a shimmy and rattle in my 06 Cobalt with 90.000 miles. When I'm going 50-60 my front end rattles and the steering wheel shakes. Sometimes it's really bad and sometimes it's not. When I'm going around a turn the shaking stops. This happened back at 40,000 miles also and I believe they replaced a bushing of some type, what bushing would that be?
does the gear grind occasionally when putting it into gear with the clutch pedal pressed down?
the shaking could be a control arm bushing, my second guess is an axle. could also be a tie rod end or ball joint.
Yes, the gear does occasionally grind even with the clutch pedal pressed.
it started shaking before we lowered it though
Updated first post
