2007 Pontiac G5 2.2L
I have a 2007 G5 that is totally stock. It now has 140,000 miles on it and has just started making a slapping, clicking or ticking sound (depending on speed) emanating from the driver's side wheel well area. It doesn't affect the drivability at all but is alarming to hear.
I have checked to see if anything was stuck in any bottom turning parts but haven't found anything. Does any one have an idea about what I should look for and in what order?
Engine noise or chassis/tire noise.
Too many things it could be.
Can you safely jack up the wheel with the proper tools and turn the wheel by hand?
Discussion Starter · #3 ·
Thanks for trying to help! I've determined that it's the driver side CV axle.
you can get Axle sets fairly cheap through parts geek and a few other sites, while you are down there, better check things like control arms, end links, wheel bearing and knuckle health, and Strut/Spring wear. when i replaced my axles, i used that opportunity to replace all the other things down there and install coilovers - just figured I would throw a few ideas your way while your are making that repair :cool:
Discussion Starter · #5 ·
Thanks for your thoughts! I was looking at other opportunities and I will be replacing the strut assy's at the same time. :giggle:
