1 - 9 of 9 Posts
I've noticed this since I've had my car. My power windows are really slow, they probably go up and down half as fast as they should. I have a 2 door, 2005 LS. Unless I was given 2 bad motors, what else could it be. I haven't had any electrical power trouble, and my battery is the original one from GM. Thanks :)
Lubrication of the rails. Grease has dried up. Just need to clean and relubricate. Once you have it apart you will see where it is needed.
Sweet, thanks :)
I guess they NEVER lubricated them when they assembled the car, or just didnt lubricate them enough . . . thanks again :)
joe
They lubricate thembut the grease dries out with time. The change is so gradual that you think it's normal until you see somebody else's go up and down real quick.
I guess you have to pull the inner door trim to do that....
What type of grease would you use to lub the rails...
White lithium I believe, make sure it is good to -40°C (-40°F).
I used that white lithium grease about 9 months ago and it is just slower I thought lithium grease gets dried out easy with a lil heat????
1 - 9 of 9 Posts
