I know the title sounds funny but yes I actually turned green like the hulk and smashed my window handle into my door...like the male par coming through the door.... I was wondering if there is a way to convert to power windows
I think you just need a motor that mounts inside the door panel onto where the handle would go. You may need to shorten the piece that sticks threw the door panel that the handle slips on to. Then just wire it up to a switch and give it power.
Going to a fully stock power window option will be more complicated. You'll need the stock buttons, lots more wiring, and I assume you'd have to tinker with the BCM
Of course if you screwed up that piece the handle goes over, you may be SOL
