1 - 11 of 11 Posts
nope. Is your heat shield bolts loose?
sounds like the header-downpipe gasket is no good or the exhaust manifold gasket. Did you use the aftermarket gaskets or the OEM ones?
I bought a set of OEM ones for $20 total for both and never had that issue before. Most aftermarket header gaskets are garbage.
How many miles ....recent maintenance, any mods..? Have you tried checking your timing chain tesioner....because thats what it sounds like to me.....if so i would refrain from driving as you run the risk of severely damaging the engine:worried:
1 - 11 of 11 Posts
