1 - 20 of 125 Posts
Here a List of all The SS Parts that fit on the Base LS LT Models
Suspension:
FE 3,5 Shocks
FE 3,5 Struts
FE 3,5 Springs
FE 3,5 Front Sway bar
FE 3,5 Control Arms
Wheel hubs
Strut tower mounts
Rear axle
FE 5 Steering rack
Engine:
Exhaust Manifold
Downpipe
Exhaust
Intake Manifold (Will Physically fit but TB will not bolt up)
#32 Injectors Fit Leak free, Tuning is needed.
Pistons
Rods
Valve Springs
Supercharger and Throttle Body with Intake Manifold (tunning needed)
Drive Belt
Interior:
All of It
Exterior:
Front Fascia
Rear Fascia
Rocker Panels
Deck Lid w or w/o Wing
Rims (07 only if you have factory alloys wheels.)
Headlights (SS are slightly tinted. I believe 07 has no orange reflector over DRL)
Sneezing Daily
DO you possibly have the drivers side Plastic A-Pillar cover with Pod available. If so how much, PM if Possible?
wow thanks admin!
Great write up ... hopefully this goes to great use
FYI:
Front Sway bar:
FE1 (LS/LT) and FE3 (SS/NA/Sport) sway bars use the same links on each end/side but the FE5 (SS/SC/TC) uses shorter links. Make sure to get the shorter links if you go to the FE5 sway bar.
Shaft, FRT STAB:
FE1 Shaft PN 10392766 18mm
FE1 Insulator PN 15821022 (2 ea)
FE1 Clamp PN 22608428 (2 ea)
FE1 Link PN 15782690 (2 ea)
FE3 Shaft PN 15782694 22mm
FE3 Insulator PN 10370616 (2 ea)
FE3 Clamp PN 22608428 (2 ea) (yes, same as FE1)
FE3 Link PN 15782690 (2 ea) (yes, same as FE1)
FE5 Shaft PN 15233085
FE5 Insulator PN 15822993 (2 ea)
FE5 Clamp PN 10389617 (2 ea)
FE5 Link PN 15787554 (2 ea)
Bolts and/or nuts that hold the shaft are the same between the models.
Bolt (for clamp) PN 11516328 (2 ea)
nut (link ends) PN 11514598 (4 ea)
hey does LT and LS parts fit in the base LS
I'm not sure what you mean?? An LS is an LS plain and simple..
i mean can i put parts that was in a LT into a LS
Most of the body, suspension, and interior parts on a Cobalt are interchangable between models. Obviously not all 4 dr sedan parts fit on a 2 dr coupe.
As long as the 2.2 is the same version most of those parts will fit too (not LAP to L61) -- and the ignition systems are not interchangable between 05-06 and 07-08 2.2s
i mean can parts from a LS or LT with power fit into a base LS
1 - 20 of 125 Posts
