1 - 13 of 13 Posts
I have noticed the ss/sc doesn't have a grill but an open hole in the lower portion of the front end and the ss/na which has basically the exact same front end (atleast the 07'), has a plastic grill in the bottom portion of the bumper. Is there a reason for this? Just curious?
The grille fits in both models. The SS/SC got the chin spoiler and the SSNA got the grille. I think the 06 SSNA version originally didn't come with the grille -- you had to order it as an accessory, while it became standard on the 07s.
Discussion Starter · #3 ·
Yeah, it came on mine but I took it off to take a look at the front end and see if I liked it off rather than on the car. Haven't put it back on yet. Damn rain and cold weather came back. I was just curious if there was a performance objective with the SS/SC not having it. I have yet to see any SS/SC's have a grill.
What is the "chin spoiler"... I don't see a difference in the two front ends?
Maybe because it's just plastic and "pops" in. Look at any SS/SC -- they come with a chin spoiler. You won't see it on an SSNA unless the owner bought an SS/SC fascia and SS/SC chin spoiler.
front bumper
does anybody know about installing a SS/SC bumper on a LS? is it just a direct bolt on? Also, does it sit down lower than the LS front end, almost forcing me to get the backend and the side skirts so my car doesn't look dumb?
The front "Fascia" from a SS/SC or SSNA will bolt up to an LS/LT. You will need the left and right brackets that go between the bottom of the skirts to the bottom of the fascia -- the SS fascias are about 2 inches lower than the LS/LT fascia (the brakets fill in the gap in the wheel well as well). Also to complete the job you'll need the air dam that goes on the bottom of the radiator support -- the LS/LT air dam does not fit on the SS fascia. If you have the front mud guards they will break-up the visuals so that the SS fascia doesn't look "dumb". If you want the SS/SC fascia you'll also need the chin spoiler -- SSNA fascia doesn't have the slots for the chin spoiler.
Discussion Starter · #7 ·
So it's not possible to install the chin spoiler on a SSNA? Also, you mentioned the "air dam" that goes on the bottom of the radiator support? Does that connect to the front fascia? I looked at mine and I noticed some holes that go around the bottom of the front bumper but nothing is connected to them? I can look directly down between the front bumper and radiator and see the ground, is that supposed to be that way? Also, my front bumper seems really loose? It looks like it's only held on by 4 bolts (2 on each fender) and some plastic pins along the top. I can actually move the front bumper up and down (not alot) but it has a decent amount of movement. ??
G
The grille was the first thing I put on my SS/SC... did that before I even had the first 1000 miles on the car.
I don't know why the SC didn't have a grille insert... it's absolutely essential to keep debris and dirt off of the aftercooler.
One rock or small animal is all it will take... kiss your radiator goodbye... overheat the engine... all downhill from there.
Believe me... I've had friends get taken out that way.
As far as the front bumper moving... it's just plastic... there isn't really anything behind it except for the impact bar in the middle... it moves all over the place.
In order to put a SS/SC chin spoiler on the SSNA fascia you would have to cut off all the tabs and use double sided tape -- not recommended. The SS air dam goes around the bottom 2 pins of the radiator (you have to unbolt the radiator and lift it just enough to install it -- or remove the 2 lower frame brackets -- that's what I did) and then there are 2 plastic fasteners that go into the 2 holes in the lower radiator support.
The looseness of your fascia is normal. There are some screws that hold it at the bottom of each side as well as the wheel well, 2 bolts on each side behind the headlights and the 4 plastic retainers on the top radiator support. The grille is held in by the chevy logo, 2 large plastic screws and tabs all the way around.
thanks a lot, that really helps, i started searching the web and found a sit where I think I can buy some of that stuff from, can you tell me which i would need to buy?
GMPartsDirect.com - Find a Item
also, does anyone on here have some before and after pictures of putting a SS bumper on a LS or LT?
that'd be awesome, thanks again
Give me untill tomorrow morning and I'll get out my receipts from CED and give you the part numbers of everything needed for the SSNA.
Note that the fascia comes in a box too large to ship normally. The cost to ship is too high so you will need to buy it from a local dealer. You could print out the cost from the GM Parts Direct Website and show it to your dealer's parts department and ask them to sell it to you at that price or "trade".
Very good idea
Here are the parts you'll need to install an SS/SC or SS/NA fascia on a LS or LT:
12336074 Fascia SS/NA
22699897 Deflector (Air Dam) SS/NA (sits under radiator)
11518017 Retainer for Deflector (2ea)
15773841 Center Grille SS/NA will fit SS/SC
11609406 Screw (get 6 will need extras)
11513599 Nut (get 6 will need extras)
19120184 Fascia SS/SC
12336084 Extension (Chin Spoiler)
10134407 Retainer for Extension (4ea)
22718757 Deflector (Air Dam) SS/SC (sits under radiator)
15248110 Bracket RH SS/NA/SC (need 1 for NA or SC)
15248111 Bracket LH SS/NA/SC (need 1 for NA or SC)
Not cheap! I recommend getting a few of the extra screws/nuts listed. You can reuse ones from your fascia but will need a few more. You have to have the 2 brackets or the bottom will "flop" in the wind -- nothing to attach to. The SS fascias are about 2" lower then the LS/LT Fascia -- about the level of the air dam under the LS/LT fascia. To keep it from looking "off" you can either get the side skirts or install the mud gaurds to break up the line of the car.
1 - 13 of 13 Posts
