Hello I'm installing a Kenwood ddx396, and the stereo I had before this one was also aftermarket. Issue I'm seeing/hearing is everything sounds amazing in aux mode but it's complete opposite when I turn the car on. Any ideas of where I need to spot check.
Discussion Starter · #2 ·
Grounding and same size cables for power and grounding are key. The feedback was from the amps with different size cables.
By different sizes cables are you referring to the power abs ground cables? I have cheap-o used battery cable that I wired my amp up with with no problems. Is it possible the cable you were using had high resistance?
