1 - 20 of 46 Posts
ive got a 2005 ls mostly stock and im heading up to milan dragway this friday and i was just wondering if i could get a rough idea of what my quarter mile time might be? Any input would be appreciated
Thanks.
hahhahahhahahhahhahahhahhahahahhahahahhahahahhahahahahhahahahahahhahahahahhahahahaha, 17 is about right.
london didn't you remove your backseats? that should make it a weebit faster wouldn't it
The back seat is like 50lbs out of a 3k car. Not much of a difference!
let us know what times you put up. my guess is 15-16sec
---------- Post added at 01:50 PM ---------- Previous post was at 01:49 PM ----------
what does the ss/sc and tc put down in a quarter mile?
Not really, but no better place to start then somewhere! Good luck and let us know what your times are.
Banker, left my phone at home. I'll stop out at Sonic's after dinner tonight. I get home around 5ish
I knew there was an easy conversion, thanks bro!
Every 100lbs is a .0001 of a second gain
Actually, every 10~ WHP or about 100~ish lbs. is nearly a tenth of a second off the quarter mile.
I had an '07 LT Automatic with the following things done to it when I went to the strip and this is the time I pulled the time on the left:
Mods and anything done to it at the time were...
Progress RSB/Eibach springs
Hard pipe from factory TB to stock air box (modded) with a K&N drop-in
Headlight removed for airflow
Muffler deleted
Spare tire/jack removed from trunk
Hubcaps knocked off with tire pressure set around 30psi in the fronts (I had 205/55/15's instead of the factory 185's...so I probably could I cut pretty close to 16 flat in a pretty much stock car if I gutted it.
1/4 times are making me miss the strip, I had the ss go as slow as a 15.4 on bad run to a 14.2 with stage II and tune and then a 13.5 when I went to zzp header/dp and intake and another tune plus driver mod. Plenty of things to improve too, my 60ft was never great.
1 - 20 of 46 Posts
