1 - 20 of 21 Posts
so i have the regular sound system and added a 10' sub with a 2 channel amp to my system.
i recently got the stock sub with box from the cobalt pioneer sound system. it has four wires going into a clip coming out of it. how would I go about wiring it in with my existing system?? so I would have 2 subs with my current amp one from the stock pioneer system and the other my sony xplod.
I'm not familiar with that sub but I don't know why the 4 wires. Is there an amp built into that sub?
Maybe someone can help that has that Pioneer system already installed. I don't have that system in my LT Sedan.
I did the sam ething but had the now defunct Circuit CIty do the install of the amp and wiring. You will need the bolts from GM to mount in factory position, save money and only order the bolts, go to your local hardware store and get the nuts for them.
Discussion Starter · #6 ·
yep i know how to mount it in the factory position thanks lol, just wondering about the wiring.
The factory Pioneer sub is a dvc sub, 2-2ohm voice coils. Each set of wires on the sub encloser is wired to one of the voice coils.
Discussion Starter · #8 ·
thanks all i managed to figure it out, had nice pounding bass for about 2 min till i blew the stock sub, blew all my fuses to the amp too. now i'm looking at buying a new sub to put into the stock enclosure. apperntly my amp put too much power to the stock one....
i tried putting another sub in the stock plastic box, sounded like sh!t.
Does the stock sub fit all year models??
it should. dont see why it wouldn't
Dont guess many people have done this wouldn't hurt to try there not very expensive.
probably wouldn't. most people pull em so you can probably get it for next to nothing... or go to a pick a part and see if u can find one
how big was the amp im planning on 200 something small.
still depends what brand youre going with. eg JL amps put out about double the normal running of a Sony thats rated the same
Im sure this one puts out a little less its quite old ive had it forever and its off brand.
what is it?
1 - 20 of 21 Posts
