You should have loosened it before you jacked the car up.
Impact might work now, where are the spring compressors ??????
it takes alot of sudden pressure ur best chance is a impact wrench if not ur prob gonna wanna mount it back up on the car and use a breaker bar
I figured out that there is a strut nut removal socket it looks like a big spark plug socket and you use a torx bit to hold the strut still while turning the socket. No impact needed. Air would be quicker for sure.
