Hello everyone,New to the site. I have an 08 Cobalt LT. Sometimes my windows will not roll down,as if they are stuck in the up position. It will seem to be trying to go down,can hear a slight click and the interior light slightly dims,but no movement. Eventually it will work fine. Anyone else had this?
Sneezing Daily
I have never heard of it. What window does it happen with, does it happen when you try to roll down the window using the switches on the drivers side or the passenger side?
Mainly the passenger rear window that will not move.
one of the others did it once or twice. This is from the drivers controls. Maybe it will get worse so warranty will fix it. It acts the same way as if the window was already up and you still try to raise it,you hear a light click type sound ,and overhead light slightly dims for a second.Its like its stuck,and with enough tries it finally pulls loose and lowers.
2005 ls, left rear window would not roll down from driver control or left rear passenger. I held down both driver and passenger window switch and it rolled down and has worked ever since?? WTF?
