can i still keep the stock head unit and everything and still hook up subs and a amp? or will i have to buy a new head unit and install that too?
any help is appreicated
its a 09 coupe.
Aftermarket Amp
You can still have an amp installed and keep the factory setup. I had an amp installed in my LS to power the factory GM sub that I bought off ebay. By the way it sounds better than the factory setup a fellow worker has in his SS. But that also may be because i Dynamatted the trunk before the install.
yeah the best way to do its getting a Hi/low converter.... its easy to intall it bc you can just clamp it underneath the rear speakers and that gives you RCA outputs to hook up an amp... that hi/low converter its about 15 bucks in Best Buy..... I had my set up like that until about a year ago but this kind of set up doesnt give a good precision sound; mostly aftermarket units have a crossover built in thats separates bass, mids and highs.... now everything i have is aftermarket (see my signature)...
