1 - 11 of 11 Posts
I hear it mostly when I turn left, on the left side of steering column or the suspension or something (idk) the noise is in synch, not random as if there was a rock stuck somewhere bouncing around.
There has been construction and no way to get out of my neighborhood without going over a compact, pot hole filled, gravel area and there are a ton of those rough cement bumps in the road for a half mile once out of the neighborhood.
Worried I messed something up going too fast through the construction zone : ( my dad doesn't know what it might be.
CV joint maybe if the noise is in sync with tire rotation velocity.
Only when it's moving. Which doesn't really makes sense to me.
And no it doesn't seem to pull,only a tiny bit, my car drives pretty straight.
The way to diagnose this is go, with a friend, in a parking lot where you can make a full circle. Turning in a sharp left circle have friend walk besides the left front wheel. If he hears a crunching grinding noise coming from the center area of the wheel chance are you have a bad CV (Constant Velocity)joint and you are going to need a new one
or preferably a complete new axle since the inner tripod joint has the same mileage.
Ok I'll do that tomorrow.
If it is that, is it easy to fix? Jack it up and swap them out sorta thing, or a project I'll have to take to the dealer?
1 - 11 of 11 Posts
