1 - 8 of 8 Posts
I use Mobil 1 oil. Do you think it's worth using synthetic transmission fluid when it comes time to change it?
Thanks!
Only problem with that is you will need to flush the transmission and empty the torque converter because you can't really mix the 2 it tends to foam. Unless U have a manual of course.
Use Dexron V, its OEM for GM products. Putting in aftermarket trans fluid on a stock automatic trans will cause whipping and possibly 2/4 and low/reverse clutch damage.
1 - 8 of 8 Posts
