1 - 17 of 17 Posts
I have been piecing together my system for awhile now but it is finally coming together. The reason it is taking so long is cause i buy stuff when i have some extra cash. I have 2-12" alpine type e subs in a sealed box and a 1800 kenwood amp. I also have a jvc head unit i will be installing soon i just have to wait till i get that special wiring harness. my question is will i have to run a capacitor for my system? The sales rep at best buy said no but I don't know if id trust him. thanx in advance for the help.
a capacitor is never NEEDED, it doesnt hurt to run a system without a capacitor, a capacitor jsut makes things better... kinda. What a capacitor does is it builds up a charge from your battery and holds it until what ever it is hookd up to needs it. In this case your subs. So it holds a charge until you subs hit and then releases it. The point of this is so that yo lights and other electronics in your car dont dim or get less power because of the insane amount of power needed for the subs. But after you turn your subs up high enough a capacitor doesnt really do anything. I have a capacitor in my trunk right now, and really it doesnt help that much.
So i would say no you dont need one, especially them being like 100$ +. But it will stop your headlights from dimming by alot, but will never completely stop them from dimming.
I recommend if you were going to get one, take that money and upgrade to a better battery for your car, or just another battery to run all your add ons too, system, neons etc. Another battery is the only way to completely stop dimming of lights from your system. Next best thing is a better battery next best thing is a cap.
Discussion Starter · #5 ·
i have another quick question. i was wondering if there is a way to turn off the amp when i don't want the bass going but still have the radio on. I thought maybe a switch inline on the remote wire would work? would it or is there a better way?
you could turn the bass down on the head unit so i doesnt hit at all. you dont have to shut the amp off. my head unit has an option to turn the woofer on or off. And almost all amps come with a remote where you can turn the bass up and down with. but the easiest way is to turn it down with the head unit. making a switch would be kind of tedious because of the size of the wire used to power the amp, finding a switch to wire it too would be annoying but i could be done.
Discussion Starter · #7 ·
k thanx for the help. i was wondering too if anyone is familiar with the KAC-9104D kenwood amp. it has the speaker level input wiring with it. now to use that would i just tap into the rear speaker wires then plug it into the amp? i might do this temporary until i have money to switch out my head unit to one with preamp outs. anyone done this before or know how it works? i heard u don't have to use a remote wire either is that true.
Discussion Starter · #8 ·
i just figured id give everyone an update on the system. i got everything hooked up and tweaked my settings and man does it pound. i run it with bass about half way up cause all the way up is too much although i do crank it once in awhile too show off =). i didn't install the jvc head unit yet though. i will do that when i get money. thanx everyone for the help.
Discussion Starter · #10 · (Edited)
This is before i ran all the wiring. The only wires in the pic are the speaker wires. All of my wires are ran under the carpet for a clean look. I will get some new pics up as soon as i can (its night time right now haha). Tell me what you think.
Actually, making a switch wouldn't be hard at all. You would just need to put a switch on the remote turn on wire which is only a 18-16 gauge wire. We do that for ppl all the time where I work when we install multiple amps and stuff. Like if they're running 4 subs, 2 to each amp, we will run a switch on the remote wire for each amp so they can run only what they want. Takes about 30 seconds to do.
Discussion Starter · #12 ·
thats what i was thinking of doing. i might do that when i put my other head unit in. right now i have speaker level inputs hooked up to the back speakers to get my signal and turn the amp on and off and all that. so for now i just turn the bass way down haha.
Discussion Starter · #14 ·
i got the box before anything. i got it from best buy real cheap. it was a display box for awhile so i got it for 40 bucks. its a q logic sealed box. it normally goes for about 100. good deal huh? haha
Very clean look to that system man....next do the front and rears
Sneezing Daily
on the note of the swith, it will work, i just did this today. Hook it up to the remote section as ur saying, but on the switch it goes one side is for the accessory (remote wire coming from amp) and the positive (comes from power terminal on ur amp) then ur done, it should work after that.
1 - 17 of 17 Posts
