1 - 13 of 13 Posts
How do I take off my tail lights?
Discussion Starter · #3 · (Edited)
coupe
and i need to know reverse lights too
ok yah i dont know about the coupe's never done couple tailights before i'm sure some one will by the end of the night tho and post it up for you
Does ur car have the carpet thingy on the deck lid? (mine doesnt) well, first u'd take that off, i'd assume it just snaps off. Ok, on the rev. lights take the bulbs out by just turning them & the whole housing just comes right out, then unscrew the 2 or 3 nut lookin things (i forget what size, so this may not be too helpful) after you get those off take a flathead screw driver and push those little clips in, BE CAREFUL becase if ur not the rev light will POP out & slide down ur trunk & may scratch ur paint (i did this, lol). Pretty much the same thing on the actual taillights except you gotta pull the carpet back in the trunk to get to the nuts, but it has the little clips too. Once you get everything ready to go gently pop them out. I hope that helps!! I'm bad @ explainin things, but Ive done this a kazillion times b/c ive painted my tails so much! haha
Open the trunk.
Remove the trunk lid fabric if you have it.
Remove the nuts from the taillights
Remove the taillights
Installation is reverse
Straight from the Haynes manual but shortened a little and more to the point
i believe one bolt is 10 mm and another is 11.
i took out my tails and put ipcw in during the winter.
Discussion Starter · #8 ·
thanks everyone. when i first tried taking the reverse lights out, i didnt see that there were nuts to take off. i just got done nite shading them and just waiting to clear coat them
lol, just make sure that you wont get pulled over even though you'll get a warning. its embarrassing...been there.
Discussion Starter · #10 ·
i didnt put a lot of coats on. i think i put 5 real light coats so it doesnt look too dark
good call man. i put on 5-6 moderate coats and it looked downright great..but the state troopers didnt think so. if you ever need to get it off though, goo gone. its amazing
Discussion Starter · #12 ·
haha ok thanks, im goin out now to put clearcoat on
1 - 13 of 13 Posts
